dkrivosheyev
Thread starter
I believe the whine issue is two-fold if it happens on a new car:
1. The tolerances in the differential gear assembly from the factory may be such that there is too much play in the gears and that can cause the whine.
2. Item (1) combined with the transmission fluid that is too thin can increase the whine. Event with the tolerances are good the differential can experience some whine if wrong (too thin) fluid was used.
I suggest you try redline D4 in this corolla and see if the whine goes away.
