Originally Posted By: rpn453
Originally Posted By: BetaBear
Patches are unsafe when they are done on W or higher rated tires or within 1" of the sidewall. When either of these are present, we replace the tire.
Would it be safer for me to drive at 70 mph on a patched S-rated tire than my patched Y-rated tire?
Sorry, should rephrase that.
It is not safe to patch a W group rated tire because the patch will not hold up to the tire's alloted speed rating.
Therefore, we do not patch these tires because the plug isn't up to the tires speed standard, and is a huge liability.
We also don't fix tires with just a plug. Pull the tire off, put it in the tire holder, and patch/plug from the inside of the tire out. I'd only use those plug/rubber cement kits in a pinch to get to a shop and get it fully repaired.
If they just patched it without demounting the tire... That's just quick shotty work there. Like those cheap alignment places that just "Set the toe and collect the doe". If you paid for a 4 wheel alignment, you should get the whole alignment. Just like if you paid for a patch job, you should get a full patch job, not just a "Plug it and go".
A plug and patch reinforces the area where the hole was. The plug fills the area with new rubber and helps seal the hole. The thick patch on the back is about 2" in diameter and almost 1/4" thick that goes over the 1/8" hole that screw or nail just made. It is attached to the rubber plug stem you pull through, and this 2" plug gets vulcanized to the rubber on the back of the tire. This reinforces the tire, and then you seal it by running a special tool over it.
The difference between the plug you get for bike tires and for emergency kits like in the 'Slime' kits, vs. the patch/plug I've described is that one reinforces the area, while the other doesn't and merely seals the tire from air escaping.
