Originally Posted By: morris
"Lots of silly advice in the above posts." i have seen it. back in the dark ages i was working at a trencher mfg. they took a machine and jacked it up, then ran the engine at full rpm for 8 hours straight, in 3 days the engine would not turn over, a Wisconsin v 4. the bearings was spun, DA. just cause you havent heard of it doesnt mean it isnt so
I would think that unless they ran it out of oil, or there was a fault in the machine work (crank/rods/mains), that it should have taken the abuse. Those old Wisconsin engines didn't turn a whole lot of RPM.
Now, if the oil was old and broken down or they messed with the governor to purposely over speed it, then yeah, it would be bound to fail.
