I'd like to get some insight into this problem..
My Corolla 4wd 1.8 7afe burns oil whenever i go downhill in gear with my foot off the gas (engine deceleration), huge amounts of blue smoke. It takes a few seconds with WOT after downhill run to clear all the smoke.
If i open the throttle plate just a tiny, tiny bit or put the gearbox in neutral (it's a manual) and idle while going downhill i have no oil burning problems at all. It does not produce blue smoke under any other circumstances. Compression is 190 180 180 180 no change with/without oil in cylinder.
I think it sucks oil through the PCV system, due to the very high manifold vaccum at engine deceleration.
I've replaced the valve and checked the hoses but it doesn't help. There's a good amount of oil residue in the intake manifold.
Now the thing is, i just put in a "new" used engine.
I had exactly the same problem with my old engine with the blue smoke on downhill runs, except my old engine had no power and used way too much gas. The new engine is peppy and gets good MPG's. When i got the used engine the spark plugs looked good (slightly tan) for a healthy engine, but now there's quite a bit of black deposits on them.
The only common factor between the two engines is that I'm using the same kind of non-OEM oil filter. The PCV is also a non-OEM (AC Delco).
Why does it burn oil like this and what can i do to stop it. I've tried various engine oils and there's no difference. It does not consume any oil at all if I'm careful and always go idle downhill, but it's a chore and I live in a hilly place and MPG's do take a hit with all that idling downhill rather than engine braking where there's no gasoline used at all.
The only things left that I have not tried is an OEM oil filter and OEM PCV. Do you think this would even make a difference?
