Originally Posted By: rufushusky
Anyone else see the flyer below:
http://archiesfordstore.com/Diesel_Oil_Reference_Sheet.pdf
Is the FL1995 really an 18 micron oil filter? I thought it was 20 @ 60% and absolute around 35. Did they change suppliers or is there another MC filter for the 7.3?
The spec sheet says:
"Traps at least 98% of particles 18 microns or larger from your oil"
That's a pretty good beta/efficiency rating. Wonder if all Motorcraft filters are that good, or if this is for the 7.3L Engine filters. Note the efficiency rating is specified as not as good for the 6.0L Engine.
For automotive applications, Motorcraft has always stated "80% at 20 microns" efficiency, which is nothing to get excited about.
Yeah I was under the impression it was around that efficeny too. If that is the case the 10 dollar or so FL1995 is the best bang for the buck you can get.
I work in the warehouse of an oil distributor, and all employees get extreme discounts on product. On a friends last day working there, I suggested he stock up on filters for his PSD. We went and looked at the Motorcraft filter, which was $9.95, and we looked at the Pennzoil PZ49, Performax PO49 and Valvoline VO-63 oil filters. They are all 4 made by Purolator, and they all looked exactly identical. The Valvoline filter was just slightly more than 1/2 as expensive as the Motorcraft, and the Pennzoil and Performax (a Pennzoil brand) were just slightly more than that.
I see no need to use the Motorcraft branded filter in this particular case. Find a local oil distributor and buy a case of one of the above part numbers.
