Originally Posted By: Spyder7
Originally Posted By: k24a4
Regarding the settling of MOS2 I'm a bit unclear. The solid particles are held in suspension within the bottle ie. no shaking is recommended or necessary prior to adding it to the motor oil. So, no settling occurs in the bottle itself. This is true in my own experience of the product; it was uniform in consistency and color coming out of the bottle.
I don't think it really means anything that settling occurs or not in the bottle; the bottle is not subjected to the prolonged engine operating temperatures that mos2 is. In the longer threads on it there was discussion that it seemed to take anywhere up to a few hundred miles or so, for the plating effect to occur. It then seems to "linger" in the engine, or much of it does, after the oil is changed, and some use it every other OCI for this reason.
I only noticed the silvery color the first time I used it, and that was just for a little while after I put it in. After that, within a thousand miles, the oil was "dirty brown" again. I skipped it the following OCI, added it the next one (this OCI), and didn't notice the color change this time (whatever that means).
FWIW I've only tried it twice, half a bottle to a 4 quart sump at the beginning of the OCI. Maybe the silver tint on the dipstick depends on the ratio added.
-Spyder
IIRC it was the people at Rosemill Industries producers of MoS2 that told me MoS2 was a great additive in oil, however it never took off with oil companies because it does eventually settle out of the oil. Tungsten Disulfide is also very good in oil but settles out very quickly, and is more expensive. The settling is not a problem because as I mentioned above as soon as you start the car it goes back into suspension and is circulated in the engine. It takes about 500 miles to "plate" the engine, so as it is deposited you'll notice less on the dipstick, and as the oil becomes dirty with use you'll hardly see it. Depending on sump size you can also notice more of a silvery color on the dipstick. My 4.5 qt Aerostar's dipstick shows more silver color than my 6 qt E-150 sump both using a full bottle.
