2011 Honda Pilot v6
Factory fill
6242 miles and 8 months
Oil life monitor at 10%
approx 80% of miles were 10mi commute each way. Remaining 20% is highway long trips.
I refilled with Mobile 1 and a PureOne filter.
Code:
Comments: We're glad that you dumped this factory oil in your 3.5L, because it always has a bunch of junk in it
from the wear-in process that can get abrasive if left in place to long. Metals are a little higher than we
typically see in wear-in samples, so that might be the case here. Things should clear up after 2 or 3 more oil
changes. Universal averages show typical wear levels for this type of engine after about 6,000 miles on the
oil. The viscosity was in the 5W/20 range and the 1.8% fuel dilution isn't a big concern. Try just 5,000 miles
on the next oil to wash that stuff out.
mi on oil 6242
mi on unit 6242
sample date 1/28/2011
make up oil added 1 qt
ALUMINUM 34
CHROMIUM 5
IRON 85
COPPER 203
LEAD 6
TIN 0
MOLYBDENUM 272
NICKEL 1
MANGANESE 12
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 78
SILICON 70
SODIUM 53
CALCIUM 1515
MAGNESIUM 136
PHOSPHORUS 592
ZINC 733
BARIUM 3
SUS Viscosity @ 210°F 45.7
cSt Viscosity @ 100°C 5.95
Flashpoint in °F 330
Fuel % 1.8
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.4
Factory fill
Code:
mi on oil 6242
mi on unit 6242
ALUMINUM 34
CHROMIUM 5
IRON 85
COPPER 203
LEAD 6
TIN 0
MOLYBDENUM 272
NICKEL 1
MANGANESE 12
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 78
SILICON 70
SODIUM 53
CALCIUM 1515
MAGNESIUM 136
PHOSPHORUS 592
ZINC 733
BARIUM 3
Fuel % 1.8
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.4
