Can't believe I fixed it
by Stelth
02/25/18 04:40 PM
Cruise Control Set at 55
by das_peikko
02/25/18 04:39 PM
Who here has satellite radio in your vehicle?
by ZZman
02/25/18 04:01 PM
Oil choice for new to me 07 escape V6
by gabriel9766
02/25/18 03:10 PM
Super cleaning windshield
by mclasser
02/25/18 02:36 PM
New WM oil filters...
by rollinpete
02/25/18 01:49 PM
Swapped Out Bunch of Indoor Flood Bulbs to LED ...
by LoneRanger
02/25/18 01:45 PM
Scanner ABS Transmission and Engine Codes reader.
by littleant
02/25/18 01:38 PM
Meijer - Quaker State buy one, get one 50% off
by Bighorn2500
02/25/18 12:50 PM
Anyone own a 3rd generation Toyota Tacoma
by 007
02/25/18 12:47 PM
Best "wax as you dry" type spray wax?
by aquariuscsm
02/25/18 12:39 PM
Any current Edge 0W20 users here ?
by aquariuscsm
02/25/18 12:27 PM
Which one?
by RogerBacon
02/25/18 12:25 PM
VW Polo, 1.4 TSI 150hp (ea211) 0w-30. 11700km
by VTS16
02/25/18 12:16 PM
Atlanta Quick Trip 500
by bdcardinal
02/25/18 11:58 AM
Gumout One N Done vs All In One
by Patman
02/25/18 11:44 AM
ACEA A5/B5 vs ACEA A3/B4 for Volvo V60 Polestar?
by A1ex
02/25/18 11:36 AM
Vogue Signature V tire review
by 2strokeNorthstar
02/25/18 11:33 AM
Which have improved faster - engines or oils?
by HawkeyeScott
02/25/18 11:12 AM
PP 5W20 bottom of jug debris
by aquariuscsm
02/25/18 11:05 AM
A1ex, Grozd, swc, coronad0, davidsain
64288 Registered Users
96 registered (08versa, 901Memphis, andrewp1998, A1ex, 2015_PSD, ammolab, 5 invisible), 1815 Guests and 92 Spiders online.
64288 Members
65 Forums
278790 Topics
#1863998 - 04/19/10 09:49 PM 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 mi
LoneRanger Offline
Loc: Midwest USA
--- 51,000 miles on car, 9000 miles on the oil. ---
Not sure about this. Iron seems high, even though Blackstone seems unconcerned. Boron most certainly gets used up because VOA's of this oil have shown boron @ over 200ppm.
No trending data because this is first oil analysis ever. Prior oil was Mobil 1 TDT and before that Castrol SLX Professional OE 5W30 (505.01), and before than Castrol TXT 5W40. Oil filter is VW OE bought at dealer parts counter (Hengst?...)
Should also be noted that about 2/3 those 9000 miles on the oil were urban/suburban short trips and most of that during midwest (cold) winter. Morning startups were after sitting in heated garage (garage temp @ 55 F on avg duiring winter) but only a 5 - 7 mile drive to her work, then cold parking lot start up at 5pm and short trip it home 5 - 7 miles.
Blackstone seems happy with it, so I guess I should be happy. Not sure I want to go for 11K miles on the new fill of this same oil, though. Maybe 8000 next time to match the universal avg they mentioned.
'09 Subaru Forester ...................(QSED DEXOS1 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
#1866028 - 04/21/10 02:04 PM Re: 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 mi [Re: LoneRanger]
sasilverbullet Offline
Loc: San Antonio, Texas
I have a 02 Beetle Diesel - Just curious why you run Mobil 1? That oil is no longer 100% pure synthetic if I'm not mistaken.
I run Amsoil European Formula in my Bug (and all my other vehicles). I've been running 7K intervals on the oil changes.
14 Honda Civic 4dr EX-L-M1 0W-20 & WIX XP
14 Honda Accord 4dr EX-L 4cyl-M1 0W-20 & WIX XP
02 Chevy 5.7L van-GTX HM 10W-40 & WIX filter
#1867001 - 04/22/10 09:30 AM Re: 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 mi [Re: sasilverbullet]
LoneRanger Offline
Loc: Midwest USA
Mobil 1 ESP uses a group IV base oil, and is made in the European Union. Its not the same as regular Mobil 1, and it is 507 approved as far as VW oil specs go. 507 supercedes VW oil specs 506.01 and 505.01, and can be run in the Pumpe Duese VW TDI's (model yrs 2004 - 2006 in North America).
The car is now going to be logging mostly highway miles, with her having started a new job that requires an approx 50 mile commute each way, most of it on the interstate. This higher accumulation of miles will have me doing the next oil change in about 3 and half months. I used Mobil 1 ESP 5W30 again and plan to run it to 9000 miles once more in order to have an apples-to-apples run on the oil to see which way Fr (iron) wear goes. It should trend downwards with highway cruising becoming the predominant driving.
#1867281 - 04/22/10 01:38 PM Re: 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 mi [Re: LoneRanger]
Boatowner Offline
Loc: Kingman, Arizona
I switched to the Motul 507 5w-30 oil one year ago. This from Motul 505.01 5w-40 oil. I noticed my mpgs went up slightly. I change at 6,000 miles. Anyone who objects to that is welcome to pick up my used oil for their TDI PD. My next change, in 1,000 miles, will be to the Mobil 1 5w-30 ESP based on price. My understanding is the formulation is pretty much the same as the Motul with more esters than a 505.01 oil.
My rubber band change is due in 7,000 miles and then I will really get an idea of how the engine is doing. Until then, I have not looked into the engine and don't intend to do so.
05 Jetta TDI Wagen, 12 Pilot, 10 Vulcan 900 Classic LT, 07 Searay 185 Sport
#1867291 - 04/22/10 01:51 PM Re: 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 mi [Re: Boatowner]
LoneRanger Offline
Loc: Midwest USA
I think a lot of the 505.01 oils use Group III base oil. Motul does tend to use more ester base than most anyone else.
#1914308 - 06/05/10 07:54 PM Re: 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 [Re: LoneRanger]
Tornado Red Offline
Loc: Saint Paul (ex-San Diego)
Instead of the Mobil 1 ESP Formula 5w30, I would recommend the ESP Formula M 5w40 for the TDI PD engines -- and the newer TDI CR engines after the warranty. Not a whole lot of difference between the two oils, but I think the 5w40 is just a little more robust. It might reduce the Fe wear numbers...but even if it doesn't, it will still do a good job over the normal 10k-mile OCI.
'03 Golf TDI, 668k miles: Bosio DLC764, GT1749VB, Malone Tuning, G60/VR6, Bilstein HD, Recaros, Akebonos, Pirellis, DG Panzer
#1915004 - 06/06/10 03:16 PM Re: 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 [Re: Tornado Red]
LoneRanger Offline
Loc: Midwest USA
Thx, I will keep that in mind. Next oil change only a couple months out... she's racking up the highway miles with her new commute now.
#1915514 - 06/07/10 05:28 AM Re: 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 [Re: LoneRanger]
Mokanic Offline
Loc: North Carolina, USA
Not trying to change the subject but what can these VW approved oils do that a good CJ-4 oil such as Delvac,Rotella,Delo,Schaeffer,ect. could not do?
#1948232 - 07/09/10 07:53 PM Re: 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 [Re: Mokanic]
LoneRanger Offline
Loc: Midwest USA
Meet VW warranty requirements.
Some TDI owners who are out of warranty period do use CJ4 oil though. Mobil 1 Turbo Diesel Truck is growing in popularity among TDI enthusiasts.
#2173658 - 02/17/11 08:49 AM Re: 2005 VW Beetle TDI -- Mobil 1 ESP 5W30 -- 9000 mi [Re: LoneRanger]
riggaz Offline
Loc: England
No ester as a rule in the road going Motul oils, not unless stated on the can, just group 3
Racing oils have ester
