My Saab 9-5 has a service bulletin regarding switching from steel wheels for winter back to the alloy wheels in the spring. Apparently there can be some corrosion on the wheel hub to wheel mating surface.
The service bulletin says to use "White high pressure paste grease or similar" on the mating surface after cleaning them when switching back to the alloys.
What would all of you fellow BITOG'rs recommend for this application? Thanks!
