Originally Posted By: Hokiefyd
I generally prefer timing chains as well, but you have to be careful with assuming that ANY chain drive system is more reliable than ANY belt drive system. There are some pretty poor/noisy chain drives out there. On the other hand, there are some fantastic chain drives as well.
I used to be of the mindset to avoid anything with a timing belt, by definition. Now I see myself about to purchase a vehicle with a timing belt. As it sits, I'd be 50k miles away from the timing belt change interval on this vehicle, and a DIY replacement costs about $350 and 5 hours. I can live with that.
+1 Early 2000's V6 Trackers and Vitara's had timing chain issues, it seems the tensioner would stick and the chain would get looser and beat the guides to death before failing... I think its because the tensioner doesn't move potentially for years at time, so [censored] oil run to long could have build up and make it stick and not add tension as the chain wears, accelerating wear.
Its not unheard of for the 4 cylinder to have timing chain issues as well, and the water pump is chain driven... I run HDEO's for their detergents and hope for the best.
