I recently had my serpentine belt replaced for my '06 F150. It was "chirping" and the dealer put another Motorcraft belt. About 5k miles later, the noise is back on the new belt. When I went to inspect it, I noticed it had gummy deposits on the non-ribbed side of the belt as well as on the pulleys. Anyway, after two failures I've come to the realization that I may have created the problem by typically cleaning the engine compartment whenever I go to the car wash. I have a theory that the soapy water may have stayed on the belt creating an emulsification of dirt, soap residue, and whatever else is under the hood flying around. I think this residue causes the belt to slip on the pulleys.
Anyone routinely clean/wash their engine compartment and eventually have belt failure (belt noise/squeal)?
