This 3M system looks to be what I have. The picture of it is on the first page, but the description is on the 3rd page.
http://www.steelwheelweights.com/pdf/APR_weights.pdf
"The wheel weight
is made of a highly flexible and conformable
polymer composite material that can be cut
to length to meet exact weight requirements,
according to Scott Taylor, automotive technology
manager for 3M Automotive.
The composite material is made up of
both polymers and metals. Recycled materials
make up 89% of the composite
material.
Compared to other weights, the 3M wheel
weight system requires fewer part numbers,
says Taylor. “One or two part numbers can
take care of a tire dealer’s entire inventory.”
The wheel weight material is flexible enough
to be cut with scissors, yet tough enough to
withstand rigorous durability, weathering,
salt spray and “salt fog” testing, he adds.
The wheel weights do not clip onto the
wheel; they are attached using 3M Acrylic
Foam Tape."
BTW, we had the wheels on our T&C balanced this summer in PA, on a road trip, and they used steel clip-on weights, and I like those a lot better than the lead clip-on weights that I've had before. The steel ones look much cleaner for some reason.
