I find this question interesting, and some of the ideas give me some. Here is an idea that could work on a small block Chevy, but I don't know what other engines.
Pull the distributor and the oil pressure sending unit behind it. Introduce solvent, oil or a mix into the pressure sending unit port while turning the oil pump backwards with a drill. Let it flow out of the drain plug.
If you knew where the pickup was in the pan you could make a nozzle out of a piece of tubing that would point up into it that passes through the drain plug hole. Using a pump of some kind you could shoot solvent up through the pickup and let it flow out of the drain plug hole.
If you knew where the pickup was located you could drill a hole in the pan and shoot solvent straight up into it. Then weld up the hole if a steel pan. If an aluminum pan you could drill, tap and plug the hole.
These ideas may not be real practical but just food for thought.
