I have thermal/electric activated chokes on my ATVs. I wish they never had it. Every time you start the engine, warm or cold, it goes through the choke procedure causing the engine to rev unnecessarily high when the engine is already warm. When the engine is revving high, it's difficult to get the automatic transmission to engage. It's like it has some kind of safety feature that will not allow the drive to engage until the rpms fall. I've figured out a way around it by leaving the machine in gear and starting it with the brakes applied. I have a similar machine with a manual transmission and it does the same thing with the choke but being a manual, I can put it into gear with no problems. These chokes are electrically controlled and work on a thermo-couple principle. The choke is always on when the machine is turned off. When the machine is turned on and electricity goes to the choke, it slowly warms up the thermo-couple to slowly disengage the choke. Regardless of engine temperature, the choke always seems to go through the choking process. PITA!!!
