9 919adamj Joined May 31, 2010 Messages 3 Location Japan Jun 5, 2010 #1 I got alot of 7808 and was thinking about doing a mix with diesel. I was thinking about doing a 50% mix of the too but not sure if it will work any insight will be helpful.
J JAG Joined Oct 23, 2005 Messages 5,316 Location Fredericksburg, VA Jun 5, 2010 #2 I'd be concerned about its effects on any elastomers and plastics it will come in contact with. It also can damage some paints. Here is a product data sheet for an oil meeting that spec. http://www-static.shell.com/static/se-sv/downloads/produktblad/aeroshell_turbine_308.pdf
eljefino Joined Jun 15, 2003 Messages 40,479 Location ME Jun 5, 2010 #3 http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Main=133013&Number=1908824
