229.51
by RogerBacon
02/22/18 06:25 AM
One way to get the rust off under your vehicle...
by rollinpete
02/22/18 04:04 AM
Loud hum noise from front brakes
by Jimmy9190
02/21/18 10:47 PM
Rat: Trap or Poison
by WhyMe
02/21/18 10:27 PM
STIHL Hp ultra fail??? Or my fault???
by Matt2stroke
02/21/18 09:42 PM
Wrestling pretzel hold. Ouch!
by callbay
02/21/18 09:41 PM
Serpentine Belt noise
by Tdbo
02/21/18 09:31 PM
Coolant Leak
by Ducked
02/21/18 09:13 PM
Does lots of starts let gas get in oil?
by tc1446
02/21/18 08:44 PM
Avalanche front and rear diff change.
by spasm3
02/21/18 08:40 PM
Abuse proof rental home flooring
by Oldtom
02/21/18 08:17 PM
Low Noise Oil
by Ducked
02/21/18 07:55 PM
2017 Dodge charger review
by gabriel9766
02/21/18 07:51 PM
Dry reusable air filters?
by WillB
02/21/18 07:42 PM
Batteries @ Menards
by Tdbo
02/21/18 07:29 PM
Blotter Spot Test
by Emanuel
02/21/18 07:22 PM
Is arming teachers the answer?
by ZZman
02/21/18 06:45 PM
Another ATF question... I aplogize
by bardos
02/21/18 06:12 PM
To Seafoam or Not?
by Marco620
02/21/18 06:07 PM
2017 Ford ecoBoost 1.5 Oil Filter Top View
by tenderloin
02/21/18 05:50 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
54 registered (aquariuscsm, Armkb, 2015_PSD, 4WD, alarmguy, 4 invisible), 1082 Guests and 100 Spiders online.
64253 Members
65 Forums
278522 Topics
Page 2 of 4 < 1 2 3 4 >
#1869499 - 04/24/10 04:26 PM Re: High Copper on Schaffers UOA [Re: 07GreyLBZ]
JD4440 Offline
Loc: Orlinda, TN
Originally Posted By: 07GreyLBZ
Thanks for the information. I will call the dealership that did the work and see if the copper based lubricant might be the case. Also, I refilled using 9 qts Schaffers 7000 15w-40 with 1 qt Schaffers #132 EP Moly Additive. I did this to keep the the OCI as close to apples to apples as I can. I agree, everything else looked really good. I normally run this set-up out to 10K miles without much thought. I just thought that I'd run an analysis on this batch of oil because of the injector failures looking primarily for excessive fuel. On a side note, I do use the Schaffers Diesel treat 2000 mixing 3 oz. with 26 gallons of fuel.
Just wondering why the combination of oil? 7k and 9k. Is the moly lube widely used ?
o6 duramax = Mobil Delvac
o6 Vortec 8.1 = Shell 10w-30
o4 Yukon = PU 5w-30
99 Sonoma= Mobil 5w30HM
2008 Hustler Z = Amsoil ACD
#1869596 - 04/24/10 05:57 PM Re: High Copper on Schaffers UOA [Re: JD4440]
Steve S Offline
Loc: East of IGO
See what the next uoa shows, then worry!!!
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1988085 - 08/16/10 08:49 PM Re: High Copper on Schaffers UOA [Re: 07GreyLBZ]
07GreyLBZ Offline
Loc: Central, OH
Well I got my latest report from Blackstone today. It read as follows:
Sample was run for 10,326 miles on Schaeffers 15W-40 w/ Mobil 1 303 filter.
AL 3
CR 1
FE 29
PB 7
CU 305!!!!!!
Moly 305
Tin 0
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 3
Boron 7
Silicon 8
Sodium 11
CA 1528
MG 860
Phosphorus 1137
Zinc 1554
Barium 0
SUS Viscosity @ 210F 84.3
cSt Viscosity @100C 16.59
Flashpoint 435F
Fuel <0.5%
Antifreeze % 0.0
Water % 0.0
Insoluble % 0.3
TBN 4.8
This was a lot of highway miles with light towing daily. What can possibly be causing this much copper consistantly in the 2 UOA's. I am about to go to Wal-Mart tomorrow and buy the Delo 400 for $8.50 p/gallon and call it a day. Anyone have any ideas on this. Possible impending premature turbo failure????
#1988870 - 08/17/10 03:34 PM Re: High Copper on Schaffers UOA [Re: 07GreyLBZ]
07GreyLBZ Offline
Loc: Central, OH
Also, note the viscosity climbed out of the 40W range. Could theoil be too thick for the turbo bearings possibly??? Just trying to get a handle on what could be happening here. Thanks.
#1988913 - 08/17/10 04:08 PM Re: High Copper on Schaffers UOA [Re: 07GreyLBZ]
salesrep Offline
Loc: lllinois
This is a good read
http://www.machinerylubrication.com/Read/646
"It seems to boil down to three things: zinc dialkyl dithiophosphate (ZDDP), heat and new engines. The principle elemental component of ZDDP is sulfur."
High quality Specialized Lubricants pay for themselves!
#1989195 - 08/17/10 08:56 PM Re: High Copper on Schaffers UOA [Re: salesrep]
Tempest Offline
Loc: Las Vegas NV
Excellent article!
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#1989277 - 08/17/10 10:31 PM Re: High Copper on Schaffers UOA [Re: Tempest]
07GreyLBZ Offline
Loc: Central, OH
Ok, so I read the article you mentioned, which was very informative...thank you. It mentioned that the copper typically happens in new engines less than 1,500 hours. My engine has almost twice that. (2,800 hours) The last 2 UOA's have shown significant CU and FE compared to similar engines, uasgage, mileage, etc. The last batch was run primarily on the interstate at 70MPH and no heavy towing. (Less than 5-6,000 LBS)Always cool down after a long run and don't flog on it until properly warmed up. Any other ideas?
#1992632 - 08/20/10 08:58 PM Re: High Copper on Schaffers UOA [Re: 07GreyLBZ]
07GreyLBZ Offline
Loc: Central, OH
Well, I dumped the most recent batch of Schaeffers after my last UOA showed a lot of CU. I replaced it with the Delo 400 LE that's on sale at Wal-Mart for $8.50 p/Gallon. I plan on resampling at 3,000 miles and see where the CU levels are at. The Schaeffers was in for a little over 1,000 miles. So, I would think that I should get a somewhat better idea on what's going on here. Could the high viscosity on the last UOA be too thick for the turbo bearings? I'm just taking a shot in the dark here.
#1993493 - 08/21/10 08:26 PM Re: High Copper on Schaffers UOA [Re: 07GreyLBZ]
panthermike Offline
Loc: Phoenix, AZ
I'm doubting the Schaeffer's is the problem, I'll be interested to see the results of the Delo though!
'16 Ram Sport 1500; Havoline/Biotech, Wix 21K
'10 Impala; PHM/ Biotech, MG 111K
'70 F100; Valvoline 15w40/Biotech, Motorcraft
#1993659 - 08/21/10 11:22 PM Re: High Copper on Schaffers UOA [Re: panthermike]
07GreyLBZ Offline
Loc: Central, OH
I doubt it also, but I wanted to make a switch and do a process of elimination. If the oil isn't the problem, then would that mean the oil cooler or something else that has a copper makeup be on its way out? Maybe someone here knows what may be the cause of the copper.
#1994011 - 08/22/10 12:41 PM Re: High Copper on Schaffers UOA [Re: 07GreyLBZ]
demarpaint Offline
Loc: NY
I'd wait two OCI's before drawing any conclusions with the new oil. It is possible the Schaeffers oil isn't the best choice for your engine hide, but a 3000 mile OCI isn't going to give an accurate answer. Going by what I've learned here it is best to run an oil 2 OCI's before jumping to any conclusions. If your 3K sample shows an improvement in Cu that would be a good sign, if it doesn't then I would suggest re-sampling after 2 OCI's. JMO
God Bless Our Troops
#1994024 - 08/22/10 12:52 PM Re: High Copper on Schaffers UOA [Re: 07GreyLBZ]
panthermike Offline
Loc: Phoenix, AZ
I totally agree with you there. Switch oils and make sure it's not the oil :)
#1994171 - 08/22/10 03:44 PM Re: High Copper on Schaffers UOA [Re: panthermike]
07GreyLBZ Offline
Loc: Central, OH
When my CU jumped from 173 to 305, that tells me that something is definatly not right somewhere whether it's the oil or something else. Does anyone know or have any experience with the possible mechanical problems that could be occuring here???
#1994335 - 08/22/10 06:38 PM Re: High Copper on Schaffers UOA [Re: 07GreyLBZ]
salesrep Offline
Loc: lllinois
Tubo bearings may be a good call. Have you researched and/or posted a question on any of the vehicle/manufacturer forums?
#1994590 - 08/22/10 10:45 PM Re: High Copper on Schaffers UOA [Re: salesrep]
07GreyLBZ Offline
Loc: Central, OH
Not as of this moment I haven't. Probably wouldn't be a bad idea though. Thanks for the advice on the manufactuer's sites.
