Ford E350 Ambulance with the 7.3L turbo diesel, 88,440 mi on unit
Delo 400 LE 15W-40, 4,694 mi and 15 months on oil (ambulance service so from an hours stand point this drain is probably equivalent to about twice the odo mileage.)
2 Qts make up oil
Napa Gold oil filter
Analysis by Schaeffer's
Cu---2
Fe---19
Cr---2
Al---4
Pb---1
Mo---70
P---1092
Z---1250
Mg---349
Ca---1877
Na---11
K---0
Antifreeze, fuel, H20=0
Si---4
Visc @100C= 14.16
Ox---7
Ni---8
Soot--- .1
Oil analysis sure can be a useful tool. When I first took my job and started an oil analysis program this unit had a severe intake leak that was found via analysis and repaired by an outside shop. The iron, chromium and nickel were all very elevated. Since the repair the metals have been trending down nicely.
This oil was drained and I refilled with Schaeffer's Supreme 7000 15W-40.
2 Qts make up oil
Cu---2
Fe---19
Cr---2
Al---4
Pb---1
Mo---70
P---1092
Z---1250
Mg---349
Ca---1877
Na---11
K---0
Si---4
Visc @100C= 14.16
Ox---7
Ni---8
Soot--- .1
