I was changing the oil in my truck (the one in my sig) a week ago and noticed half my oil pan had a coating of oil on it. Further inspection revealed the leak to be from the oil pan gasket and I noticed the second bolt from the front, driver side, had fallen off. I replaced the bolt and torqued all of the bolts (most had loosened up) to 18 ft.lbs, the recommended torque. Hopefully that took care of the leak.
I have had the truck since new and the pan has never been touched before. GM needs to start applying loctite to these oil pan bolts. I used the red 262 loctite but I dont know how effective it is going to be since there was oil contamination.
On a side note, I thought the auto industry had switched over completely to metric fasteners but these pan bolts were 5/16C threaded. I suppose this has to do with the roots of this engine which go back to the mid-fifties.
Anybody owning the 4.3l V6 should check their pan bolt torque.
