Originally Posted By: Gary Allan
Originally Posted By: SHAMUS
So, if I start using a Ford Racing filter instead of the regular Motorcraft FL 820S, the racing filter's much higher bypass pressure only means that more of my oil gets filtered before it opens? In practical terms, for a street v6, does it take a WOT before it opens (assuming its not clogged)?
It will reduce flow at relief compared to a lower setting filter. If you have typical volume and typical viscosity ..and typical operations there is absolutely no benefit to a higher bypass setting.
It's one step below the most foolish thing done by so many SBC hi-per strokes ..the defeat of the bypass mechanism.
"Reduced flow at relief" ... (I'm assuming he's talking oil pump pressure relief) will be determined only by the filter's flow restriction characteristics and the oil pump volume output, not it's bypass valve setting. I'd imagine a racing filter is pretty high flow, and therefore relatively low in flow restriction ... but will also probably have worse filter efficiency than a none racing filter.
The reason racers use a "racing filter" like that is so they ensure adequate flow rate (due to lower filter restriction) with an engine using a high volume pump and thicker oil. There might be some sacrificing of filtering efficiency to help achieve that. The bypass is set pretty high due to the large PSID you'd see with a ton of relatively thick oil being forced through the filter.
