Originally Posted By: Bruce T
I think Water Wetter is a very misunderstood product in street use. RL's own tech data shows that it only reduces the overall coolant temperature by 8°F with a 50/50 mix. By itself, this is not very exciting. However, it becomes significant if you take 440Magnum's thoughts a step further. If WW reduces the surface tension of the coolant, so the hottest spots in the engine receive more coolant, wouldn't this also reduce oil oxidation and sludge?
Agreed. Out on the road, my vehicles are almost always operating at the thermostat controlled coolant temperature. WW or any other surfactant can not, and should not, have any effect on this. If the patient vehicle is usually using the t-stat to control temperature, there will never be an observed difference.
What is different is that heat transfer is more efficient. There should be less micro-boiling in the block, the heater should work better, and you'll have more "reserve" in the system because it can MOVE more heat (not absorb more heat).
This is a contrast to, say, lowering the concentration of antifreeze. That increases the specific heat capacity of the coolant mix, and gives the coolant more heat carrying capacity (more heat is carried with a lower temperature increase of the fluid). This, however, won't increase the heat transfer in the system.
So, if you have an application that is often running with the t-stat wide open you may see temperature decreases from running a surfactant. You may also see less coolant temperature rise when stopped. You'd also see the same effect from reducing concentration.
I've run WW in previous cars without any issues. Only one of those cars was a bit of a heat challenge. In my current BMW, the WW broke down into thick brown greasy spooge when mixed with OEM G-48 coolant. Not impressed. Then I had to run RMI-25 to try to clean it up....
