Here you go - even has the correct torque values which are important for safety reasons:
GM Service Information
2008 Pontiac Grand Prix | Grand Prix (VIN W) Service Manual | Seats | Seat Hardware, Trim, and Upholstery | Repair Instructions | Document ID: 1715831
Front Seat Replacement - Bucket
Removal Procedure
Caution: Refer to SIR Caution in the Preface section.
Important: The front seat is equipped with a seat belt pretensioner. Disable the pretensioner before you perform any work on the seat.
Disable the SIR system. Refer to SIR Disabling and Enabling .
Remove the front seat head restraint. Refer to Front Seat Head Restraint Replacement .
Position the front seat to the full forward and the full-up position.
Remove the bolts from the rear of the seat adjuster.
Remove the nut from the front seat belt bracket, on the door side of the seat.
Tip the seat forward, remove the position assurance pin (2), and disconnect the pretensioner electric connector (1).
Disconnect the electrical body harness from the seat.
Tilt the seat forward and slide the seat back to disengage the adjuster hooks holding the seat to the floor pan.
Remove the front seat from the vehicle.
Installation Procedure
Install the front seat into the vehicle.
Engage the front seat hook attachments.
Tip the seat forward, connect the pretensioner electric connector (1) and insert the position assurance pin (2).
Connect the electrical body harness to the seat.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the adjuster to floorpan bolts.
Tighten
Tighten the bolts to 42 N·m (31 lb ft).
Install the seat belt and nut.
Tighten
Tighten the nut to 42 N·m (31 lb ft).
Install the front seat head restraint. Refer to Front Seat Head Restraint Replacement .
Inspect the front seat for proper operation.
Enable the SIR system. Refer to SIR Disabling and Enabling .
© 2009 General Motors Corporation. All rights reserved.
************** HERE IS HOW TO DISABLE THE SIR:
2008 Pontiac Grand Prix | Grand Prix (VIN W) Service Manual | Seats | Seat Hardware, Trim, and Upholstery | Repair Instructions | Document ID: 1739855
SIR component location affects how a vehicle should be serviced. There are parts of the SIR system installed in various locations around a vehicle. To find the location of the SIR components refer to SIR Identification Views .
There are several reasons for disabling the SIR system, such as repairs to the SIR system or servicing a component near or attached to an SIR component. There are several ways to disable the SIR system depending on what type of service is being performed. The following information covers the proper procedures for disabling/enabling the SIR system.
Condition
Action
If the vehicle was involved in an accident with an air bag deployment.
Disconnect the negative battery cable(s) *. Refer to Repairs and Inspections Required After a Collision .
When performing SIR diagnostics.
Follow the appropriate SIR service manual diagnostic procedure(s) *
When removing or replacing an SIR component or a component attached to an SIR component.
If the vehicle is suspected of having shorted electrical wires.
When performing electrical diagnosis on components other than the SIR system.
Remove the SIR/Airbag fuse(s) when indicated by the diagnostic procedure to disable the SIR system
* DTCs will be lost when the negative battery cable is disconnected.
SIR Service Precautions
Caution: When performing service on or near the SIR components or the SIR wiring, the SIR system must be disabled. Failure to observe the correct procedure could cause deployment of the SIR components. Serious injury can occur. Failure to observe the correct procedure could also result in unnecessary SIR system repairs.
The inflatable restraint sensing and diagnostic module (SDM) maintains a reserved energy supply. The reserved energy supply provides deployment power for the air bags if the SDM loses battery power during a collision. Deployment power is available for as much as 1 minute after disconnecting the vehicle power. Waiting 1 minute before working on the system after disabling the SIR system prevents deployment of the air bags from the reserved energy supply.
General Service Instructions
The following are general service instructions which must be followed in order to properly repair the vehicle and return it to its original integrity:
• Do not expose inflator modules to temperatures above 65°C (150°F).
• Verify the correct replacement part number. Do not substitute a component from a different vehicle.
• Use only original GM replacement parts available from your authorized GM dealer. Do not use salvaged parts for repairs to the SIR system.
Discard any of the following components if it has been dropped from a height of 91 cm (3 feet) or greater:
• Inflatable restraint sensing and diagnostic module (SDM)
• Any Inflatable restraint air bag module
• Inflatable restraint steering wheel module coil
• Any Inflatable restraint sensor
• Inflatable restraint seat belt pretensioners
• Inflatable restraint Passenger Presence System (PPS) module or sensor
Disabling Procedure - Air Bag Fuse
Turn the steering wheel so that the vehicles wheels are pointing straight ahead.
Place the ignition in the OFF position.
Important: The SDM may have more than one fused power input. To ensure there is no unwanted SIR deployment, personal injury, or unnecessary SIR system repairs, remove all fuses supplying power to the SDM. With all SDM fuses removed and the ignition switch in the ON position, the AIR BAG warning indicator illuminates. This is normal operation, and does not indicate a SIR system malfunction.
Locate and remove the fuse(s) supplying power to the SDM. Refer to SIR Schematics or Electrical Center Identification Views .
Wait 1 minute before working on the system.
Enabling Procedure - Air Bag Fuse
Install the fuse(s) supplying power to the SDM. Refer to SIR Schematics or Electrical Center Identification Views .
Turn the ignition switch to the ON position. The AIR BAG indicator will flash then turn OFF.
Perform the Diagnostic System Check - Vehicle if the AIR BAG warning indicator does not operate as described. Refer to Diagnostic System Check - Vehicle .
Disabling Procedure - Negative Battery Cable
Disconnect the negative battery cable from the battery. Refer to Battery Negative Cable Disconnection and Connection .
Wait 1 minute before working on system.
Enabling Procedure - Negative Battery Cable
Connect the negative battery cable to the battery. Refer to Battery Negative Cable Disconnection and Connection .
