I’ve posted a VOA and UOA (see separate threads) for a sample of Castrol TWS 10w-60, API SJ oil as used in a ’05 BMW M3. These are my first readings on this type oil,
and, considering the application, was surprised to find such relatively low levels of phosphorous/zinc anti-wear additive (641/796 in the VOA), although there is a good amount of boron which I believe is also an anti-wear additive.
I have one question: The oil is rated API SJ. What is the advantage or possible reason for formulating this oil to such an old API rating?
