It looks like Redline makes two CVT fluid now. MY 07 Altima uses Nissan's CVT N2 fluid. I called Redline up, and asked if their Non-Slip CVT fluid meets Nissan's spec. The tech person said yes. Here it is.
Redline
My owners manual says to use Nissan N2 fluid only. I know they wrote that so Joe the Plumer doesn't go down to his local Napa and adds Dextron III to the transmission. I woulnd't even think about putting the Redline fluid in if it didn't meet Nissan's spec. The Nissan fluid ranges from $14.95 a quart online + shipping, to over $20.00 at my local dealer. The Redline would be around $14.00 a quart.
The Altima has a drain bolt for the transmission. I have read 5 quarts will drain out. I posted this on my Altima forum. They all said to stick to what the owners manual says. They think I can't use anything else. The owners manual also says to use "Genuine Nissan parts only" all throughout it.
Would you guys risk using the Redline fluid over the Nissan fluid?
Redline
