I own a lawn & landscape company, and I have several commercial grade ZTR's zero turn Mowers: Walker, SCAG, John Deere with donaldson or nelson canister heavy duty filters. Before switching to Amsoil i would change to oil with a quality 10w-30 synthetic oil. I had one engine blow with only 750hrs. Upon repowering, we tore into the blown engine, the high engine heat & load is what caused the engine failure. Since then I switched to Amsoils: AME 15w-40 12TBN HD marine diesel & gasoline oil, with great sucess, noticeable cooler engine temps & better overall performance, I have over 5 hours with no ill effect some (LCO) lawn care operators have said I am crazy, your voiding your warranty [censored]. I feel confident the engines will out last my other air cooled Kohlers with 15w-40. My theory is based on the fact: air cooled engines are cooled by ambient air passing over the cylinder head cooling fins, and the oil cooler, but more important the oil itself, unlike an liquid cooled engine; which uses a more efficient method of cooling water, and does not soley depend on the grade & quality of engine lubricant as air cooled engines.
