This is from the tech sheet on yellow bottle Pennzoil. Says it meets that spec on 5W20, 5W30, and 10W30.
ADVANCED PROTECTION MULTI-GRADE MOTOR OILS
PRODUCT DESCRIPTION
PENNZOIL® ADVANCED PROTECTION MOTOR OIL delivers better engine protection than is required by ILSAC GF-4
or API SM and is specially formulated to provide extra protection against the harmful effects of stop-and-go driving and high
and low-temperature engine operation.
APPLICATION
PENNZOIL® ADVANCED PROTECTION MOTOR OIL is recommended for passenger cars, light-duty trucks, vans and
sport utility vehicles that are fueled with gasoline (including turbocharged). PENNZOIL® ADVANCED PROTECTION
MOTOR OIL SAE 5W-20, SAE 5W-30 and SAE 10W-30 exceed the demanding requirements of International Lubricant
Standardization and Approval Committee (ILSAC) GF-4. ILSAC GF-4 comprises the latest standard for passenger car, van,
light truck and sport utility vehicles (SUV’s) engine oils. It surpasses the performance requirements of API SM Service
Classification.
PENNZOIL® ADVANCED PROTECTION MOTOR OIL 10W-40 and 20W-50 are recommended for older engines for
which the owner's manual recommends API SM or prior API Service Classifications or any combination thereof.
Viscosity recommendations vary according to temperature and engine manufacturer. For most new cars (ca 1993 and later),
API Certified oils displaying the “starburst” symbol (indicating an ILSAC GF-4, ILSAC GF-3 or GF-2 requirement) are
recommended. Some PENNZOIL® ADVANCED PROTECTION MOTOR OIL grades also meets the Ford WSS-M2C153-
H and WSS-M2C930-A specification (SAE 5W-20 only) and the GM 6094M (SAE 5W-30 and SAE 10W-30 only)
specification. Always consult your owner's manual for the correct viscosity choice.
BENEFITS
• Specially formulated for stop and go driving
• Keeps you engine clean for long service
• Resists breakdown for high temperature performance
• Low-friction formula helps improve gas mileage (SAE 5W-20, 5W-30 and 10W-30)
• Exceeds the highest U.S. standards for automotive engine wear protection
• Protects engines under severe driving conditions and prolongs engine life
• Exceeds API SM Service Classification (all grades)
• Exceeds manufacturers' U.S. warranty requirements
• Meets and exceeds ILSAC GF-4, GF 3 and GF 2 requirements (SAE 5W-20, 5W-30 and 10W-30)
Meets WSS-M2C930-A (SAE 5W-20) and WSS-M2C929-A (SAE 5W-30)
• Meets DaimlerChrysler DC 6395N (SAE 5W-20, 5W-30, 10W-30)
• Meets GM 6094M specification (SAE 5W-20, SAE 5W-30 and SAE 10W-30)
