IEEE in their 2005 annual worst engineering ideas issue, declared Ethanol replacing normal gasoline as a terrible idea. The ethanol processing, especially in the newer,"modern" plants, use coal instead of waste plant products to run the plant. It takes the energy equivalent of 1.25 gallons of gasoline to make 1 gallon of ethanol from agriculture crops, using what is universally declared "dirty coal"
It is only tax dollars that makes it profitable.
I am a member of the Institute of Electrical and Electronics Engineers (IEEE), we are full-blown geek-heads. However, there is a limit when the gag-reflex kicks in.
