Production motorcycle, consumer oils...
http://en.wikipedia.org/wiki/Yamaha_YZF-R6
In 2006, Yamaha advertised the R6 as capable to running at up to 17,500+ rpm. This is 2000 rpm higher than the previous R6 model and it is the highest redline of a widely distributed production four-stroke engine – the Honda CBR250RR had a reputed redline of 19,000. Such a high speed is near to levels known only in Formula One engines, where valve springs stress problems lead to the adoption of pneumatic return at more than 19,000 rpm.[2]
But it was widely reported that the 2006 YZF-R6's motor did not have this redline level and was closer to around 16,200 rpm, because of a tachometer error of about 9%. In February 2006, Yamaha admitted the bike's true redline was more than 1,000 rpm lower than advertised,[3] and offered to buy back any R6 if the customer was unhappy.[4]Even though some riders have reported this to not be a problem and are actually able to rev higher than the 17,500RPM's and well in to the 18,000RPM range.
http://www.r6messagenet.com/forums/showthread.php?t=41403
Welcome to The R6 Messagenet.
The largest resource for the Yamaha YZF-R6 and YZF-R6S
Motor Oils
If you read the manual you will notice it says to use Non-EC (energy conserving) oils only. This is what you should look for on the back of the oil bottle, it will not say Energy Conserving on the bottom. Because your motorcycle has a wet clutch, and is actually partially submerged in the oil, some say your clutch will slip. Debates rage on as to whether this is a needed concern, or just a marketing ploy playing on your fears, to get you to spend extra money for motorcycle specific oils.
15w50, 10w40, 5w30 and 5w20 are the most common oils used in our bikes. Brands are generally personal preference, but most here will recommend Mobil1. Mobil1's "Extended Life" 15w50 (Red Cap Replacement) motor oil is a favorite of many, and their new "Truck and SUV" 5w30 is also a great oil, free of any friction modifiers (EC rating).
