ZINC or MOLY...which is best???
oklahoma
Okay so in experimenting with oils in my 4.0L Jeep with 80k & minor leaks, I am about to finish up an OCI with Pennzoil High Mileage 10w30 in it. As compared to the Trop-artic I had in it before, it runs quieter & smoother and the leaks that sometimes could leave a dot on the concrete have stopped.
Next on deck waiting to go in is some Maxlife 10w30. I think most High Mileage oils (including Pennzoil) have a decent amount of ZDDP in them when compared to normal oils. But Maxlife seems to be the exception to the rule and has lots of Moly but little if any ZDDP???
That being the case, does Valvoline know something the others don't or is it just that one additive costs less than another and that is how the select them?
I would want to use the High Mileage oil that has the best additive pkg and I am wondering between the two additives, which is best & why?
thx
Honestly, if your leak has stopped and improved with the Pennzoil High Mileage, keep using it. Why ruin a good thing.
Exactly...don't try to do too much Suv
Maxlife 10W30 semi syn has a good amount of zinc and moly in it. $14 for 5 quarts at Walmart.
All SM oils, both Maxlife and Pennzoil High Mileage, are SM oils, if they are fairly new. The limit for ZDDP in these oils is 800ppm.
All SM oils will usually have a ZDDP amount between about 650-800ppm. Maxlife does not have 'little if any ZDDP' - it has the same amount as Pennzoil, give or take 5%.
Moly IS more expensive to put in oil than ZDDP, which is a big part of the reason moly levels have dropped in oils in recent years. I like the idea of lots of moly in an oil, as I think high-moly oil 'generally' show lower wear amounts than others. Old Havoline, before Ds, used to have 300-500ppm of moly in it, and it showwed amazing results almost all the time.
For this reason, I like the idea of Maxlife more than other High Mileage oils - Maxlife still has over 200ppm of moly in the add-pack. BUT, as Anies said, if the Pennzoil High Mileage worked for you, don't ruin a good thing!
thx
The Valvoline Maxlife series has 830 Zinc, 760 Phosphorus, and 300 moly. If you look at their PDS, they have lowered calcium and added 490 ppm sodium. They also use a ZDDP pack that is more durable than normal, but, I believe all oils will soon be using this ZDDP pack.
There are some great discussions on moly in the forum on adds. We even had EM and Valvoline CE's come and talk with us. At 300 ppm, moly is a HEAVY FM, LIGHT AW. Combine that with their ZDDP and detergent pack and you get a great oil.
The MaxLife is 70% GPII and 30% GPIII. The MaxLife Synthetic is about 85% GPIII with some GPIV in the add pack(according to Valvoline tech)
Stick with the High Mileage if it has helped your leaks... I wouldn't worry about ZDDP/Moly in your engine because the 4.0's can't be killed easily!
Drive Happy!
Well as far as why I'd switch from Pennzoil High Mileage to Maxlife is just because I already have the Maxlife in my stash and bought it with the intention of experimentation. But in general, I think I would like YB over Valvoline conventional and so I am a little apprehensive about using Valvoline just because I never have used it in the past. I was always a Castrol & M1 man, but this site convinced me that Pennzoil is one of the best.
But I was under the impression that the Pennzoil High Mileage had lots more ZDDP than Maxlife and Max-life's main edge was that it was syn-blend and had much more moly than Pennzoil High Mileage. Can you confirm that ZDDP levels between the two are close and that Pennzoil has much less moly?
If that is the case, then I have been looking for a good oil to switch to in my 180k non-daily driver that is currently using M1-HM formula but won't even see 5k in a year so I am thinking a blend or dino might be a better choice.
Thanks again guys
Drive Happy!
Yeah they are good motors except this is an '01 and these newer ones have a nasty habit of cracked heads & busted piston skirts especially so maybe not as good as they used to be?
But this thread is now spilling over into my 5.9 magnum engine because if the Maxlife really has plenty of ZDDP but way more moly than Pennzoil High Mileage, then I might consider it for my 5.9L Jeep too.
FastSUV, I think you'll find that all the High Mileage oils will equally deal with your leak problem.
Good pt - and Schaeffers is the king of Moly. But they don't have an High Mileage offering.
It is not either-or zinc-or-moly. They work together to be better than either is alone. The zinc phosphate compounds produce a wear resistant layer on the parts. Zinc phosphate and molybdenum phosphate compounds together produce a layer that is both more wear resistant and lower friction.
http://www.sciencedirect.com/science?_ob...97674bd3014285b
Only the ILSAC GF-4 labeled oils have the upper limit of .08% phosphorus. SM oils that are not GF-4 can be higher if the oil maker chooses. Dual-rated diesel & gasoline engine oils are an example...0.12% max phosphorus with the CJ-4 and SM Service Classifications.
High Mileage oils are more about marketing than about engine protection.
Yeah, I had thought of using a HDMO but I wanted the seal additives. BUT leaks are not my only motivation for using a High Mileage oil. I wanted the added protection of the better additives. My leaks on both vehicles are not bad and I am sure I'd use High Mileage oil anyway even if I did not have those leaks but the fact that they get stopped or slowed is definitely a plus
The ZDDP & Moly will not prevent cracked heads, it might help the Piston skirts a little but I think you would have to dump even more ZDDP in the oil that was in most oils from back in the 80's.
It's a bad design in the newer engines, no amount of additives is going to fix it.
You could run a slighly cooler thermostat. This will help the head from heating up in traffic. Not too cool or you could cause an CEL!
I missed that it was an '01 in your post above.
Well I know that it will not prevent cracked heads LOL. I just recall people on the Jeep board saying that is a common issue on these newer ones. Mine has electric fan & clutch fan & 180* stsat so it NEVER heats up thank goodness.
I have years of real world evidence (on one car) that High Mileage oils are more than just marketing. I had a vehicle that had significant smoke at start-up (valve guide seals) - High Mileage oils reduce this to the pt that it was essentially undetectable - occassionally I would see a puff, otherwise no discernable smoke.
Also, I went thru all the High Mileages - started w/ Maxlife (soon after it came out), then Castrol High Mileage, then Wally ST High Mileage, and M1 High Mileage - all did pretty much equally well at eliminating the smoke. Car seemed to run the swoothest on M1 High Mileage (yes, very subjective).
There was one head casting used at the beginning of the 2000 production run that seems to have been a bit more prone to cracking. This was the first head with the bolt bosses to hold the coil-on-plug ignition rail, which is the reason there was a casting change. Apparently they also thinned out the casting, whether intentionally or or just through a problem at the foundry I don't know. IIRC, all of those heads were used up in 2000 except a very few have popped up in 2001s. Its been reported that they've also shown up in late production 1999s too. Look at the head casting number which is visible between cylinders 2&3 (or is it 3&4, I forget) right near the intake manifold runners. If it ends in "0331" its the suspect casting, if not don't worry at all.
Did you try Pennzoil High Mileage?
Are high ZDDP numbers (>1000) of any benefit for newer engines that use roller cams rather than the old flat tappet cams?
