Patman
Staff member
Keep in mind that the factory setups for a lot of things are not always the best possible choice, but are a compromise, due to budget constraints, fuel economy regulations, etc. So the tire choice for any given car is not guaranteed to be the 100% best choice, and each individual who owns the car will have different priorities there too (some might want best tread life, some might want best rain performance, others might just want max handling potential)
In terms of the factory programming, that is not going to give you max power either, nor will it always give you max fuel economy. They set it up very conservatively so that the engine does not destroy itself the first time you drive it up a steep hill in 100 degree weather. So the fuel mixture is going to be set richer than optimum.
This is why taking your car to a performance shop and getting them to dyno tune it based on your exact setup is going to be much more precise than a factory calibration which is identical for all cars.
The same goes for oil choice. I for one do not believe Mobil 1 5w30 is the best choice in the LS1 family of GM engines. I base this on seeing a good number of oil analysis reports on here which show higher wear compared to when someone tries out an oil more on the thicker side of the 30wt range. Since Mobil 1 5w30 is only 10cst, it only has an HTHS of 3.0 to 3.1, while the oils closer to 12cst, with HTHS numbers of 3.5 to 3.6, have shown lower wear in oil analysis.
GM chose Mobil 1 5w30 for the Corvette for a number of reasons, one of them being availability. You can find it everywhere! I'm also sure they've got a nice deal going with Exxon/Mobil too, something that the smaller oil companies couldn't compete with. Mobil 1 also has a big presence in the "synthetic world", the average person who knows virtually nothing about oil has still probably heard the name Mobil 1.
So along comes people like us here on BITOG, who aren't satisfied just using an oil that is good, but want something that is great! Will Mobil 1 5w30 get you 250k out of your Corvette engine? Most likely, so long as you drive it relatively gentle. But what if you're like me, and like to go drag racing once a month, and like to go full throttle a lot on the street? I doubt I'd get 250k out of my engine in that case. But by choosing an oil with a higher HTHS, one which shows much lower engine wear in oil analysis, I believe I do have a very good shot at going beyond 250k on the original LS1 engine in my 98 Corvette.
Just one more quick point. Mobil 1 5w30 tends to show higher oil consumption in the LS1 compared to German Castrol 0w30 (which is 12.2 cst at 100c, vs 10.0 for M1) as well. Many people I talk to from both LS2.com and LS1Tech.com who have taken my advice and switched their LS1 engines over to GC 0w30 from M1 5w30 come back to tell me later that their oil consumption improved dramatically. This is another good reason for switching!
