I have two low mileage 2006 Saturn Vues, both with 2WD, and the Honda 3.5 V6 MDX power trains. I know how to beat rust in southern Michigan with the right preventative procedures and the right vehicles. The objective now is to get a million miles out of them. I can see from the MileMaker site 300,000 to 500,000 happens a lot, some over 700,000, and a couple with over a million miles. The main challenge will be minimizing the effects of winter and short trips. I'm convinced that synthetics low temperature advantages can help. They've been on good dino oil and 3000 mile change schedules until now. Both look very clean when you look into the valve covers.
I've read a lot, including on this forum, about how ZDDP helps with flat tappet engines, and read oil analysis links. However, I would think that any place in the engine that tests the lubricant's shear strength would benefit as well. Any engine with even 30,000 miles will show wear on the upper rod bearing inserts. I noticed the article on this forum named Oil University is not sold on the supposition that that ZDDP is not required. I wouldn't dream of trusting the EPA to do what is in the best interest of U.S. citizens, from an environmental standpoint, or any other standpoint, or have even the slightest scientific evidence to back up their claims, nor that oil companies and auto makers can pull a rabbit out of their hat to neutralize every assault the EPA devises, which is why I surface this topic for new engines.
I intend to change oil between 3000-4000 miles to keep the engine clean. If you haven't seen the filter used on the J35, it's approximately 2/3rds the size of our kids sippy cups. The filters must either be in bypass all the time, or using chicken wire to filter with. However, I noticed the same filter may be used on many vehicles. I'll probably be going with the Purolator Pure 1.
For oil, I'm leaning pretty much toward Mobile 1 0W-20 Advanced Fuel Economy or perhaps Mobil 1 Extended Performance 5W-20. I realize Amsoil Signature is a fine oil with the ZDDP included, but I don't know of any local sources that don't charge retail plus an arm and a leg, running it double the miles would mean it would be twice as dirty when I change it, and I'd rather be able to just buy it off the shelf and do it myself or bring it to my oil change place and have it done for $10. I don't think the sales model of Amsoil would work for me. I don't do Amway either even though they have better products sometimes than you can buy in the store, even if they can make a case for being more cost effective. I can add ZDDP in the proper ratio, the question is if I should.
I appreciate your thoughts.
