Zaino All in One
Big fan of Zaino products here too. However, I use the Z2 with the ZFX additive. I put two coats on and use the Z6 spray between the first and second coat and after the second coat. The shine is phenomonal.
If you're not using Z-AIO, consider trying it. It's a real fantastic one-step product with that Zaino shine we all like. Z-AIO does the jobs Z2 and Z5 can't do.
Z-AIO is an amazing paint cleaner and works great on wheels, chrome, painted door jambs, anything that needs some light cleaning and polishing with protection. Z-AIO is also a fantastic base for Z2 or Z5. When used with Zaino Clear Seal, its about as easy as it gets which is great for those who want the shine but don't want to do all that work.
For years, decades even, I used Klasse All In One as my go-to one step cleaner wax. If I wanted to polish and shine something, I grabbed Klasse first. Z-AIO has taken over that role and I haven't done much with Klasse since.
How is the Z-AIO around vinyl moldings (bump strips), decals, letters, etc.? Does it stain vinyl like some products (NuFinish?) or is it hard to get off, or out of nooks and crannies?
Thanks.
Thanks.
It will not stain anything!
From the Zaino Website:
Should I use Z-AIO on painted plastic?
Definitely. You can and should use Z-AIO on nearly all exterior surfaces including: paint (including door jambs), glass, plastic lenses, wheels, chrome or any non-porous surfaces. Z-AIO will not stain or leave a residue.
I should have mentioned that I used Z Fusion first as the vehicle was bought used and had some swirling. Having used the Z fusion, I saw no need for the AIO, as that would have been like cleaning the paint twice. Since using the Z2/ZFX/Z6 and hand washing the vehicle, I've avoided any new swirls.
Once I finish my supply of Z2/ZFX I may give the AIO a go.
Since we're discussing Zaino here, has anyone had experience with the Z-CS?
I use Zaino Clear Seal by itself...I wash the car with Zaino car wash and then apply the clear seal...Easy as advertized...You just have to try and restrain yourself from applying too much..Just wipe it on and walk away and dries and leaves a mirror finish and it lasts several months...Use it on the glass too...
I've been using Zaino products for over 10 years.
Z-AIO is a great product but like all all in one's,the shine and protection doesn't last.
Follow up with Z2(you don't need ZFX when using ZAIO)for a better,longer lasting shine and protection.
I also use ZCS spray on and walk away after a couple of car washes.
Great products.
