Sorry -- I couldn't resist using a Madison Avenue headline to grab your attention. But I think you'll probably agree with me on my conclusion that a "premium" synthetic media oil filter is the only way to go for your engine.
I wanted some objective, authoritative information on just what level of filtration is necessary with an automotive oil filter. So, for your consideration, I've compiled here what I found. No NASA level science goin’ on here, just a layman's common sense. It's lengthy and a bit dry, yet is powerful stuff nonetheless since choosing the right filter can DOUBLE your engine life. Coming from various studies, some of the information conflicts slightly. Sources are in parentheses at the bottom.
THE DETAILS
-Metal-to-metal clearances in an operating gasoline engine typically vary from 3.8 to 10 microns (1).
-Metal-to-metal clearances in operating gasoline and diesel engines typically vary from 2 to 22 microns (2).
-Therefore, particles from 2-22 microns are most likely to cause damage (2). Particles under 2 microns will pass through without scuffing (2). Particles over 10-22 microns may cause damage if they wedge between moving parts, but should eventually be trapped by any name brand filter after repeated passes (11).
-"Controlling the abrasive contaminants in the range of 2-22 microns in the lube oil is necessary for controlling (gasoline and diesel) engine wear" (2).
-"Numerous tests and studies have shown that solid contaminants in the 1-15 micron range are responsible for the majority of normal wear within a (diesel) engine" (3).
-Most oil filters use a non-synthetic paper media (6,11).
-Typical paper media captures 40% of 10 micron particles, 60% at 20 microns, 93% at 30 microns, and 97% at 40 microns (4). In general, paper filters capture almost all 40 micron particles, and about half of 15-20 micron particles in single-pass tests (2,5,6). “Factory (paper) filters are only effective in controlling particles 15 microns and larger” (3).
-Compared to a low-end 40 micron filter, switching to 30 micron filtration reduces engine wear by 50%. Switching from 40 to 15 micron filtration reduces engine wear by 70% (2).
-Paper filters (like most paper) are made from ground wood pulp, resulting in somewhat random shaped and sized fibers/chunks, allowing for microscopic voids (11).
-Fine synthetic (man made) fibers tend to be uniform in size, shape, and texture (11).
-"Premium" filters typically include a blend of up to 100% fiberglass and polyester to fill in voids in the paper (7,11). Synthetic media has also come about since acids formed over extended 7,500 mi drain intervals have been known to damage paper media (12). If a filter's packaging doesn't mention synthetic fibers, assume it has none.
-As a group, premium filters typically capture almost all 10-20 micron particles, and about half of 5-10 micron particles (6,8,9,10,11).
-For street driving, "racing" or "sporting" filters should probably be avoided since they often -- and appropriately -- emphasize flow over filtration (8).
Additional data on DIESEL engines follows. Certainly some relevance to gasoline burners as well. Source is (3).
-The major contaminant produced inside diesel engines is soot, and soot has been proven to be a significant source of engine wear.
-The vast majority of soot particles produced are 10 microns or smaller, with 94% of soot being 1-5 microns in size.
-Over 80% of wear-generated metal particles in a diesel engine are too small to be filtered by standard (non-synthetic) paper media.
-About 98% of solid contaminants generated within diesel engines, including those resulting from wear, oxidation, nitration, and acid production, are less than 10 microns in size.
-Ultra-fine "UF" bypass filter systems for diesel engines are capable of reliably filtering down to the 1 micron level .
-UF bypass filters for diesel engines can reduce wear from 25-50%, and up to 400% in dusty or off-road environments.
CONCLUSIONS
-In review, SAE studies have proven that particles 2-22 microns in size cause most wear in engines. Standard paper media generally traps all 40 micron particles, and half of 15-20 micron particles, while premium synthetic blends trap all 10-20 micron particles, and half of 5-10 micron particles (single pass tests).
-To help understand how often oil gets filtered, a Taurus SHO club website suggests that those cars recirculate 100% of engine oil (crankcase capacity) three times each minute at freeway speeds (8).
-One might reasonably assume that, through repeated passes, the great majority of 5-10 micron particles will eventually be trapped by a PREMIUM filter, thereby mostly (although not entirely) reaching our goal of eliminating everything in the 2-22 micron range. But for STANDARD paper media, reliably filtering down into the single digits (1-9 microns) is not likely.
-Since premium filters cost only a few dollars more than standard filters, whereas an engine rebuild costs several thousand dollars, going "premium" seems an obvious, cost-effective choice.
-Fans of bypass systems have it right. Clearly they do work. “The fact that UF bypass filters drastically reduce wear has been well documented by SAE” (3).
-But for my 2002 Mopar, both now and in the future, I simply want the best full-flow, synthetic blend filter I can readily find at a local parts store. Without playing favorites, I'll simply say that some brands to consider include Mobil 1, Wix/NAPA Gold, Purolator PureOne, Amsoil, and Fram X2, to name a few.
SOURCES
(1) Industry test described by MolaKule in "Bearing Film Thickness"
(2) 1988 SAE paper by AC Filter and Detroit Diesel
(3) Paper by Donald Culpepper, Gulf Coast Filters, summarizing five SAE papers
(4) Russ Knize, Mini-mopar oil filter study
(5) Baldwin Filters website
(6) Carjunky.com website
(7) Filter Manufacturers' Council website
(8) Ford Taurus SHO club website's tech article
(9) Mobil 1 website
(10) Comments in these forums by a Wix representative
(11) Poster TC's opinions, suppositions, and recollections
(12) Various websites
