he makes less a year than a FB programmer .
Well, the vast majority of working folk do too.
Care to share the name of this dentist?Those are two some most abused practices, it's up to dentist to decide and they often do it to make extra $$. I have a friend who is dentist, some inside info, he doesn't do this and is disgusted with dentists who do.
If insurance allows for annual work it doesn't mean it needs to be done, but some dentists will squeeze everything out of insurance since they can. Many start trying to schedule patients for dental work every end of the year when they realize patient's insurance wasn't fully taken advantage of.
1. If you're moderate to high risk for cavities then yearly films seems reasonable. If you're low risk for cavities I'd go 18-24 months.It is standard practice to get an xray of the entire set of teeth annually? How about a filling that needs to be "repatched"?
I'd suggest you discuss it with your dentist. Ask why you're getting yearly x-rays? Maybe there's a reason. Or he/she might decide on a different interval.Care to share the name of this dentist?
We have some very reputable dentists in my area (also Vancouver), but the yearly x-rays seem a bit excessive, especially since I haven't had a cavities/noticeable gum recession in over 10 years.
Everyone should have and see a dentist regularly. Could you explain why @PWMDMD.I only go to the dentist when there's a problem, so I don't know what her approach to maintenance is.
Are you able to define moderate to high risk?1. If you're moderate to high risk for cavities then yearly films seems reasonable. If you're low risk for cavities I'd go 18-24 months.
2. Every single dental restoration your dentist has ever placed into your mouth has a life span and WILL need to be replaced. You also have to account for new things that come up too - there's no reason you can't get a cavity on previously sound tooth structure right next to a filling requiring the dentist to need to patch it up.
There are several common caries risk assessment tools that can be used to determine cavity risk.Are you able to define moderate to high risk?
My dentist is in Delta, if that works for you I can PM you the place.Care to share the name of this dentist?
I don't get annual x rays unless there's a problem. I just tell them I have no dental insurance and can't afford them right now. I think the x rays do more harm than good.It is standard practice to get an xray of the entire set of teeth annually? How about a filling that needs to be "repatched"?
