Yaris oil suggestions?
MSP 'burbs, MN
From a bit of Internet searching, it appears to me that both the Echo and the Yaris share the same 1.5L 4-cylinder engine (2NZ-FE).
As far as oil recommendations, I'd suggest sticking to what the manufacturer recommends (likely to be either 5w30 or 5W-20). Sticking to less than 5,000 mile intervals (what is the manufacturer recommended OCI?), I'd likely run a conventional oil such as Havoline, Pennzoil, Castrol GTX, Motorcraft, or Trop-Artic.
Mobil 1 and Toyota engines seem to do really well together!
And, as an added benefit, your friend will not have to change his/her oil as often as conventional oil, and they'll get better gas mileage!
After searching on "synthetics" I think the consensus is that you can have longer OCI's, but don't expect better mpg.
Forgive me, but, what is a Yaris? I first thought (with echo mentioned) it was a weedeater.
drewjp
Member
Member # 12581
posted 06 August, 2006 03:48
Posts: 118 | From: Michigan | Registered: May 2006 | IP: Logged |
What are you talking about???? Does Toytoa say that in there owner manual? If they do I have bridge to sell them.
I like Mobil 1 in my Saturn. It just seems to run better. As far as the sludge prone engines, they were the 3.0 V-6 1997-2001 and the 2.2L 4 1997 1997-2001. Their is more detailed info at Consumer Reports. Do a search there for sludge. They have a free article listing all the engines in question.
I have a Toyota Echo(2001)with 130k commuter miles on it. I have used Mobil 1 5w30 since the first oil change. I did try GC once and didn't like it. Now that I sold my car that I used GC in, I am going to use 2qts of GC and 1.75qts of Mobil 1 5w20 and give that a try. If I didn't have a good stash of different oils, I would use Mobil 1 5w30 or 5w20, whichever Toyota calls for at 7.5k OCI's, at least for the warranty period.
A friend just purchased a 07 Yaris. Does it share the same engine as the ECHO? Should he expect any sludge problems?
What's a good oil recommendation for the Yaris?
quote:
Toyota Yaris, a $14,000 "economobile"...
Since the Manual and Warranty needs 5k or 6 month Oil changes (which ever comes first),
I'd run a good SM Conventional oil like Pennzoil, Halovine, Castrol GTX or such in 5w30 and enjoy life.
I don't think that motor *yet* is going to 5w-20
There is no difference in MPG between Syn or conventional or synthetic blends (less than a mpg I've found in 52+k miles in my Corolla) and cost per oil change is alot less with Conventional.
No sludge problems with that motor.
Take care, Bill
