Originally Posted by das_peikko
Originally Posted by dja4260
It's a 13.5hp Briggs &Stratton. I did provide accurate numbers directly from the mower.
I ran that model number through Briggs & Stratton. They say it doesn't exist.
B&S sometimes has a different part number than the equipment manufacturer. However, for the present issue, entering the model number 13AC762F into the search on mtd site indicates this unit has a Kohler engine. I think the OP should send a pic of the engine numbers so we can first figure out what is in the mower.
Of course, as mentioned previously, all the carbs work pretty much the same for small equipment. Given that the OP already used a wire and carb cleaner and verified spark and compression, I think the next step would be to just replace the carb. No guarantees but the fuel seems to be insufficient to start the engine.
