Yamaha generator oil
Picking up a brand new eu3000iseb this week. What’s everybody using for oil in these?
I have a Yamaha f40 outboard that I use the yamalube synthetic 5w30 FC-W in. I was wondering if this would be a Good oil for the generator too? It will be used a lot in cold temps while we power the ice fishing shack with it.
Or is there another yamalube I should go with? The dealer doesn’t give me much confidence. So I’m not going by what he says. Lol. They just had the best deal on one of these so I bought from them.
Thanks!
Read manual online. It Shows “yamalube 4”10w30 Or SAE 10w30 SE OR SF.
but I will be using this in some pretty cold conditions, which was my thoughts for the 5w30 synthetic yamalube. Also, I have plenty of it as I buy for my outboard already. Just wasn’t sure the marine type oil to be different/suitable?
What’s the real difference of fc-w oil? Any negative effects from using it in a generator? Would it provide any advantage? Only asking as I have plenty of it. And will be changing it way more often than called for.
Thanks!
I’d wait for the new EU3200i.
I did see that one is releasing soon. But I decided to go with the Yamaha Ef3000iseb mainly because it’s a unchanged design for years now. Yamaha is famous for that. If it works and is reliable, they leave it alone. On top of that, the deal I was offered one that I couldn’t resist.
You can use a 5W-30 High Mileage synthetic oil. That'll cover the range of temps you'll be operating in and being synthetic it should help minimize usage of the oil. Also being a high mileage oil should make it a bit more robust.
I have that genset and its been fantastic - if a bit heavy.
I run something 0-10W-30 in the cold and 0w-40 when its hot out.
Thanks. I am actually considering these 2 options, as I have both one hand here, that use for my Yamaha Outboard, and my mowers, blowers:
1. Yama-lube FC-W synthetic 5w30 outboard oil.
2. Amsoil synthetic small engine 5w30, 10w30.
Either of these should be fine too right? I don't know the difference in FC-W vs "normal oil"
I'd use 0-40w synthetic in it since you need subzero starting. This way your covered for all the temps. you will see.
It's what I use in my SkiDoo's and all my cold weather small engines.
No way my BS gen sets could pull over fast enough to start below 0 with any more than a 0 bottom number oil.
I have the non-boost version of this genset. It’s been quite happy on 10-30 synthetic, usually penzoil platinum. No issues hot or cold.
