Xrev Lubricants
NJ
http://www.x-lube.com/xlube pg3.htm
Quote:
Polyol Esters
The term "polyol esters" is short for neopentyl polyol esters which are made by reacting monobasic fatty acids with polyhedric alcohols having a "neopentyl" structure. The unique feature of the neopentyl structure of polyol alcohols molecules is the fact that there are no hydrogens on the beta-carbon. Since this "beta-hydrogen" is the first site of thermal attack on diesters, eliminating this site substantially elevates the thermal stability of polyol esters and allows them to be used at much higher temperatures. In addition, polyol esters usually have more ester groups than the diesters and this added polarity further reduces volatility and enhances the lubricity characteristics while retaining all the other desirable properties inherent with diesters. This makes polyol esters ideally suited for the higher temperature applications where the performance of diesters and PAOs begin to fade. Polyol esters can extend the high temperature operating range of a lubricant by as much as 50 - 100 C due to their superior stability and low volatility. They are also renowned for their film strength and increased lubricity which is useful in reducing energy consumption in many applications. The major application for polyol esters is jet engine lubricants where they have been used exclusively for more than 30 years. In this application, the oil is expected to flow at -54 C, pump readily at -40 C, and withstand sump temperature approaching 200 C with drain intervals measured in years. Only polyol esters have been found to satisfy this demanding application.
For this reason, Xrev RACING Formula's premium fully synthetic base oil contains polyol ester, and provides unsurpassed performance for your engines.
Interesting read. Add bypass filtration and you're looking at a great solution for extended drains.
mmm... green oil:
Quote:
The current range of Xrev Racing Formula is the latest API SM series with its unique green formulation - another unique feature of XREV.
I'm not big on additives. It would be interesting to get feedback from people who have actually used their products.
Here, PDS, they claim:
Approved for:
VW: 505 00/507 00
MB 229.3/ 229.5
BMW Longlife-04
Porsche
I was suspicious that they are actually approved rather than recommended, so I verified that it is NOT on the MB 229.5 approval list here: MB 229.5 List . Not cool of them.
RLI, inc. is another racing lube company that blends with these esters too. I don't fly with turbine engines anymore, nor do I race. So I'll just stick to my diester, lanolin ester, polyol ester blended Auto-Rx for now.
Quote:
Polyol Esters
Another website plagiarizing my papers.
https://bobistheoilguy.com/forums/threads/an-overview-of-esters-in-synthetic-lubricants.94994/
Oh well, I suppose I should be flattered, but they should have at least given credit.
Tom NJ
Originally Posted By: Tom NJ
Quote:
Polyol Esters
Tom NJ
As wrong as it is, I'd take it as a compliment. Wow, 2x now.
