I Have a 2015 XC70 (P3 Chassis) that I want to replace condenser & compressor on.
Lots of tutorials or P2 chassis, but my Google prowess seems to bel lacking these days and no joy on P3 tutorials.
Anyone have any info? Bad timing, but I'm putting my house on the market, so I was hoping for some guidance as time is limited.
TL_DR backstory...
Clutch went out and wouldn't engage. Mag is on when AC is on, but no engagement. Pulled clutch, and a fibrous ring, maybe a dust seal(?) Fell out in pieces. Clutch surface looked ok. Upon further inspection, the groove in the compressor housing that holds the circlip, and thus the pulley, was cracked. The housing groove that holds the ring was hanging on by a thread of aluminum.
I put it back together without the circlip and the AC works, but, without that circlip, the pulley could conceivably walk, the outer clutch plate would prevent it from falling off, but might engage the AC. Been running for a week now without issue. The parts just came in. Found a shop that will evacuate, let me replace parts, then they will pull vacuum, check for leaks, then recharge.
I'm packing, cleaning the house to list it for an upcoming move, so I'm hoping to save some time from me trial and error, pulling things off to get the condenser removed.
Thanks in advance
~C
TL_DR backstory...
Thanks in advance
~C
