I just had a new OEM AC Delco AC compressor installed on my car. The old one wasn’t internally bad just had a bad pulley and clutch
With my mechanic, we took the new one out of the box, and noticed it was stiff but able to turn by hand
Meanwhile the old compressor was easier to turn. You could turn the shaft with your fingers and without the clutch plate.
I decided to install it. Vacuumed system and recharged it with the proper R134a.
Everything works great. The temps go down to 45deg F on an 84degree day and there’s no loud noises from the compressor when the AC is engaged
But when I reach under the hood and try to turn the clutch plate, I can’t do it. It’s too hard. But the engine turns it fine. It’s not slowing down my engine either.
Should I stop using the AC and maybe swap the compressor again? Or am I just overthinking things? I’m worried this might grenade itself.
