I recently did an ATF drain and fill on my 2011 Sienna which has about 150K miles on it. It still had the factory fill of WS. Only about 2 quarts came out, even after taking out the plastic tube in the pan. The drained fluid was almost completely black, and although it didn't smell burnt, it didn't smell great. I refilled with 2 quarts of Valvoline Maxlife. The transmission was working perfectly before the drain and fill and still is after. I plan on doing ATF drain and fills with my 10K oil changes for a while and see if the color starts to change. Removing that small of an amount will likely not make much of a difference but everything works and I'm not really trying to be "aggressive" with it.
I also recently did an ATF drain and fill on my 2004 Tundra which has about 150k miles on it and has seen occasional light to medium towing most of its life. It still had the factory fill of T-IV. 4 quarts came out and the fluid looked incredibly clean. It smelled like new fluid. It was only ever so slightly darker than the new fluid. I refilled with 2 quarts of T-IV and the leftover 2 quarts of Maxlife from the Sienna. No motive to mixing in Maxlife, just using what I had left on hand. The transmission was working perfectly before the drain and fill and still is now. I'm not sure I'll get in much of a hurry to do it again on the Tundra.
While I know this is only observational, I do find it interesting. The T-IV transmission fluid from my 15 year old truck that I tow with looked brand new and the WS fluid from the 8 year old van looked black. I know it is only looks and hard conclusions probably cannot be made. It just makes me wonder why? I would have thought it would have been the other way around.
The ATF dipstick on my Tundra says "may never need changing under normal driving conditions." After what I saw, they might be right. Not so sure on the Sienna though!
