Looks like the fuel pump on the Wrangler needs replacement. The OEM replacement is $400+. Rockauto is showing a Carter and a Retech. Are these any good or should I just pony up the money for the OEM?
I got a Bosch from napa. Inside the bosch box was a factory jeep pump for 1/2 the cost. Super easy to change as I did it on my lunch break and still had time to eat.
Yep, it's the pump. I was having problems before with long crank times once the jeep sat for a while, so I assumed it was the check valve in the pump not holding pressure, now it's dead. Voltage is good going to the pump, it just won't come on. I'll check NAPA, but it seems every I go there they are almost as much as the dealer.
