Maybe I'm being overly concerned but I do think it's only the pickup time but there's a noticable dent on it. Also notice a witness Mark where the filter punched theoth9rhe bag. Should I return this to Amazon for replacement?
It's the pickup. Submerged in fluid. It doesn't seal around anything.Due to it being damaged you cannot guarantee the surface is perfectly round, as a result it is possible for it to suck air by which could aerate the transmission fluid and lead to premature failure.
ThisRun it.
This was my first thought but then I saw that the black tube with orings was probably the part that needed to seal.Due to it being damaged you cannot guarantee the surface is perfectly round, as a result it is possible for it to suck air by which could aerate the transmission fluid and lead to premature failure.
You are correct, I was not paying attention when I wrote that.It's the pickup. Submerged in fluid. It doesn't seal around anything.
I'd run it.
I had one for my 6R140 punch through the box because RA crammed it in too small of a box. By some miracle it was undamaged and it's been in my SuperDuty for a few years now.
I'd check your local WalMart. FWIW, I have used the Super Tech AFT+4 with good results in my Chrysler, Ram & Jeep vehicles.Thank you all for talking me down, I'm going to run it.
Now where's the most affordable source of Mercon LV?
I usually take YouTube mechanic advice with a grain of salt but FordTechMakuloko has me convinced I have to use genuine Mercon LV. I think I will add some sort of Lubegard when I do change it as it has some shuddery downshifts occasionally.I'd check your local WalMart. FWIW, I have used the Super Tech AFT+4 with good results in my Chrysler, Ram & Jeep vehicles.
Just my $0.02
Didn't even see that one! I was only looking at the pickup tube.Are we talking about the dent in the upper left corner of the filter body or the slight irregularity in the pickup tube (which I didn't see when I replied above?
So you have good results with this in a 6R80? I'll try this as it's way cheaper than genuine Motorcraft stuff. I think I will add some Lubegard also, it shudders some now and then on downshift and feels like it's slipping on hard acceleration.Did a pan-drop change on our 2014 F-150 a couple years ago. I would have used MaxLife ATF but it was out of stock at the time so I used Canadian Tire's house brand multi-ATF.
I would not use "genuine" Mercon LV unless it was better value. I'd use whatever synthetic is easy to get at good price.
While you're in there, inspect & clean the wiring harness / connectors and add some extra magnets in the pan (keep clear of the solenoids).
