Specifically NAPA coolant.
Thanks, I'm trying to stay clear of the stealership. I've given them enough $$$.If a compatible coolant was used, I have no problem with it.
bingo.If the coolant is flushed, not just drained, any coolant is compatible.
Me tooI would just do it at home and use Napa RTU1EXT. It is often on sale (like now) and no need to flush, just drain and refill. I've got this in several Asian cars I service, including Honda, Toyota and Subaru. Really no need to pay more for the Asian-specific formulas. I've been using various house-brand extended life universal coolants for about 16 years now, no issues whatsoever.
I agree, the price is cheap enough. I've had several "long life" coolants in the 2009 Honda CR-V EX AWD. Honda brand blue, Peak brand green, O'Reilly brand green, Zerex Asian blue, and now Super Tech amber. My coolant changes always end up with interesting color combinations. It's now at 185k+ miles on the odometer and I was most confident in Zerex Asian. I'll switch back to it next time. I had a jug and half of Wal-Mart sitting around from another car and did the change after a cross country trip.I would get them to at least use Zerex Asian because that’s actually the same formula, not just the color. Napa coolant could be just rebranded Prestone product with the correct color.
At the very least I would do the research on Napa coolant. If it’s the same formula which should be PHOAT then it’s fine.
Same with Toyota forums with their read / pink coolants.So overblown on honda forums.
They think the engine will die if non oem coolant is used.
Its laughable.
Mine take 6 liters total- so not a big deal, I would rather change it more often than dig into the system due to corrosion,I have used lots of different coolant brands in many different Honda's and never had a problem with any of them.
