That's not how most of the newer style maintainers work though. They top it off, stop charging, monitor the charge, and then start charging again at a certain point. It's certainly no worse than driving every day where the battery is sufficiently charged up. I'm not sure if the temperature really matters that much with a low power (0.5 to 3 A) charger that will stop charging when full and go into maintain mode.
I am beginning to think much the same thing. As I said in an above post, when I bought the new battery and brought it home, I tested it before I put it in the vehicle. It showed only an 80% charge. (The sticker on the battery was dated 11/21). So it had been sitting for at least a couple of months.
I hooked it up to my charger, and gave it a 15 amp charge until the charger shut down. I then tested it, and it tested to a 100% charge, with 833 cold cranking amps. (The battery is rated at 750 CCA).
After I got everything installed and all hooked up, I drove the truck back to Wal-Mart to get my core charge credited. (About 15 miles round trip). I then hooked up the Battery Tender Jr. and the green light blinked for about 20 minutes, (signaling above 80% charge). Then it went solid green. (Indicating a fully charged battery in, "Float Mode").
I haven't run it today. But when I started it after installing the new, fully charged battery, it spun over like a top. The old battery tested bad, and cranked the engine very slowly. It was a 650 CCA rated battery. But it only tested to 333 CCA.... Definitely a dying battery.
And having it all but constantly charging every time I ran the truck, is hard on the electronic guts of the alternator. Especially with high under the hood temperatures. The Battery Tender puts almost zero strain on the battery to maintain it, and no strain what so ever on the charging system. And that can't help but increase the life of the vehicles charging system as well as the life of the battery. Especially on a vehicle that is driven infrequently.
