Originally Posted by MrTruckDriver
correct. I was pulling about 4500 pounds going up hill at about 30 mph.
In a one off, that's not too bad but if your routine driving requires this on a cyclic basis, it would warrant probably additional cooling.
First thing I would do is see if there is a fan configuration capable of pulling more CFM over the current configuration ( easiest way to add a little more exchange)
If it takes another exchanger then its a question of series or parallel but that cant be answered accurately unless you define the overtemp in terms of
are you adding additional heat at the source ( putting more energy into the fluid with a higher discharge temp)
or
just need a little more soak time for the exchange
or
