I want to do a complete transmission fluid change as my car approaches 100k miles (89k currently). I wouldn't even consider it without a pan drop/filter change first, though, so here's the plan.
- Pan drop/filter change. Refill with 7.4 qts ATF, as per the manual.
- Immediately disconnect Magnefine filter, start car, run 1/2 gallon through, refill with 1/2 gallon, repeat until fluid runs clean and clear.
I don't want to use more fluid than is really necessary, as I'm not planning to use a cheap fluid. The theory here is that the clean fluid in the pan will displace the dirty fluid in the trans and torque converter before finally going through the cooler, which I understand is the last stop along the fluid route before it goes through the final drive and back into the pan. The end result will be 95%+ new fluid. This is a 2000 Monte Carlo with a 4T65E trans.
The only concern is that the final drive will be dry while I'm doing this, but since the car will be in Park, that shouldn't be an issue.
Am I correct in my thinking? Any red flags?
