I'm looking for a better oil than the Skil 80111 Heavy-Duty Worm Drive Saw Lubricant that is mentioned above. I've changed this fluid in the Ridgid R3210 worm-drive saw several times and each time there seems to be significant particles in the fluid. This oil has a much lower VI rating than what I would normally use.
This is what I've found out so far:
The owners manual states, "It is recommended that the gears be lubricated only with Mobil SHC 636 Oil."
The Mobil SHC 636 is an ISO 680 with a VI of 163 and appears to be a sythetic-blend. This appears to be a good fluid to use but I could not find it in an affordable quantity.
The Skill 80111 appears to be 'Shell Valvata J' which is available in ISO 460/680 with a VI of 99/83. This is definitely not a synthetic and will cause extra drag & heating.
The MSDS for Skil 80111 lists the product as:
- Material: Valvata J Oil
- Product: 63053
- Company: Equilon Enterprises, Houston, TX.
64742-57-0 (70-85%) Gear Oil
9003-29-6 (10-20%) Isobutylene/Butene Copolymer
61789-97-7 (3-9%) Tallow Oil
The high-performance synthetic worm-gear oils that I found ( polyglycol fluids from Mobil, Shell, Catrol, Fuchs, etc) were not available in quantities less than 55gal or 20L. So, the search continues.
