Originally Posted By: Clevy
Originally Posted By: Gokhan
Conventional 10w30 and 10W-40 for 20 years (a lot of Valvoline and Castrol) followed by a 6-year streak of Mobil 1300 Super 15w40 CJ-4 HDEO. I think HDEO did the most harm. I have been using TGMO 0W-20 SN synthetic for the last 2 years and I am absolutely loving it. It is undoing the damage done by the HDEO and previous conventional PCMO.
Interesting.
So you figure the tgmo is cleaning it up then?
Why do you feel the hdeo did the most harm. I assumed that they would be good at cleaning based on having to clean up after a diesel.
Does this engine maybe not run hot enough for a hdeo and therefore doesn't take advantage of the potential ability to clean
It's more of a speculation but I was worried about HDEO being too thick and not flowing well. Does an HDEO clean better than a PCMO? I think it's more of a myth than anything else. HDEOs have a lot of dispersants (for soot) that you don't need in a gasoline engine though.
I have no intention of doing a valve-clearance adjustment any time soon -- which is an unnerving adjustment because I have to race against the time as the adjustment needs to be done with a hot engine before it starts cooling down. Therefore, I don't know how it looks under the valve cover at the moment. The engine runs great on TGMO 0W-20 SN though -- smoother than ever with any oil and the UOAs seem to be improving with every OCI -- which is a good sign.
