WIX Question
CA
It's kind of a dumb question, but I figured that I ask it anyway.
Why are WIX filters so popular on this site? Why do so many BITOGers choose them over Purolator?
What makes you a loyal Wix user? Performance? Value? The fact that it's the official filter of NASCAR? Or Made in USA?
Just curious.
Wix brand filters are of higher quality and filtration ability than the base filters from most manufacturers. If it says Wix on it, you're not getting a low end product.
I know we are in the oil filter section, but for me every Wix air filter has been poor quality compared to OEM. I've got alot of Toyotas - 2002 Corolla - WIX filter was deformed and did not fit in air box (got a replacement - the same for No. 2) - went with OEM DENSO from Stealership - so much better
2007 RAV4 - seal of WIX filter wold not seal in airbox, lid rattled around and sucked in air on the seam, replacement was deformed - OEM DENSO fit like a glove, filter material was considerably more robust, and seal around edges was top quality.
I don't cut open oil filters, but if anything like the quality of their air filters - no thanks...
Critic, you made me laugh tonight. Thanks.
I like WIX for the reasons stated above and I especially like that NAPA can have just about any WIX filter I need in less that 24 hours. Ag equipment, grounds equipment, generators, fuel storage tanks....you name it.
I never tried to get a Puralator filters for my workplace John Deeres. Do they have the wide selection Wix has? Anyone?
Stooge, I have decided that for some car models, aftermarket air filters can be hit or miss. The Wix air for my Caravan and Escorts are great. For my daughter's Sebring they went to another supplier and it fits bad. Other aftermarket air filter manufacturers also outsource some filters and quality can vary. It's not a perfect world anymore.
I like them because I've *never* had a bad one (which I can't say for most other brands- I've had at leaky anti-drainback valves in every brand I've tried except Wix and Purolator) Also when you open them up they're simply constructed better than most others. Good media construction, metal end-caps, etc. They also seem to apply exactly the same construction practice to their "consumer grade" (automotive) oil filters that they do their industrial filters. Darn sure can't say that about Fram- their industrial filters (big diesels, hydraulic fluid filters, etc.) seem pretty good, but their consumer grade stuff is just fancy advertizing and gimmickery (ooh look! A grip made of rhino-liner!) on an average-to-below-average design.
That said, Purolators are also excellent and I tend to use them interchangeably with Wix. They don't have the nice coil type bypass spring that Wix filters have, but otherwise they're equal. The PureOne line even has a little better base gasket material than Wix, IMO.
I did learn one thing just now- I had no idea Wix was the "official filter of NASCAR." And I even *watch* NASCAR, their ad campaign must not be very effective ;-)
Yep. Just about anything that I need is available from WIX. From coolant to fuel filters for my oil burner (big dual 3/4-16 thread diesel filters for my oil fired boiler) ..hydraulics ..they got it all.
High Quality & Great Construction, a oil filter you can have total confidence in to do its job.
For me it is the High level of Performance at a great price
I purchased my 2009 WIX Oil Filters online for $3.88 each and that included shipping.
! Where!?
Do try cutting one open you'll see in a hurry there top notch
filters,them and NAPA golds.
My wix air filter is made great. It has a sturdy OEM quality paper media and a nice thick rubber gasket that seals the airbox perfectly.
My last one was fine also. any brand you can some bad ones that slip through the cracks.
Impressive construction and quality. Great value for the price.
