Originally Posted By: azsynthetic
All on the road vehicles except for a small amount of trucks spend more time sitting still and engine off than moving. At rest, the oil in the bypass filter is most affected by gravitational settling. Once settled, the particles are tougher to move again due to the density and smaller porosity of the media.
Could that not be also said of any filter, even full flow filters? So, going back to your previous statement, you said that gravitational settling would make the bypass filter "better", but based upon your explanation, that advantage cannot exist because it disallows the claimed superiority when the very same circumstance exists in any filter. Your statements are contradictory, are they not? Also, are you ignoring the comments I made that both filters in my example are 21um nominally rated? There is no "smaller porosity media" in my example. You've attributed a condition to the situation that does not exist.
As for the Corning link; I must admit that's a bit of a hard read. That article is about DPFs and their effects with gaseous mediums. DPFs are depth-bed type media and not the relative thin-based typical cellulose media with liquids such as oil. The two are not directly comparable.
Quoting a short bit here:
While the clean FE increases with decreasing all median pore size, a significant increase in clean
filter pressure drop is observed for wall median pore diameters ...
What that means (and most of us would probably agree upon) is that as a filter becomes loaded with particulate, its pore size constricts, and that increases the efficiency of the filter. It also increases the velocity of the fluid through the filter media as best it can support the Bernoulli priciple. And it increases the deltaP across the media.
More of the article:
The filter microstructure not only has influence on the clean filter filtration efficiency, but also on the evolution of the FE as soot is captured in the filter. As the soot gets deposited in the microstructure, the soot itself acts as a filtering medium and thereby contributes to the increase in the FE. The FE gradually increases from the clean filter FE to full efficiency (100%) ...
Also, in section 4 "Conclusions":
It is estimated that while Brownian diffusion is efficient in capturing particles less than 30nm and interception/inertia is efficient for particles greater than 300nm, it is the intermediate range from 30 to 300nm that no mechanism is dominant ...
OK - first, we cannot really apply this DPF-gaseous filter example to a liquid oil filter; there is no reaonable cause to assign such assumptions. However, what we can glean is that Brownian diffusion is only effective at ULTRA small particle sizes (below 30nm). 1um = 1000nm. So, it's reasonable to presume (admittedly with no direct evidence from this article) that Brownian particulate diffusion would have little to no effect in a traditional liquid oil filter, expecially one with 21um nominal rating! The pores are WAY too large to have the Brownian diffusion effect efficiency. Kind of like worrying about how fast a mouse may run through the cattle gate, as if he slowed down he might get caught up in the opening ... The two filters I mused about were both 21um nominal; I seriously doubt Brownian diffusion will greatly effect the filter efficiency one way or another. And this article you touted does nothing to convince me otherwise. It's an interesting article; it has little if nothing to do with oil filters.
Neither of your explanations are valid for your claims against the examples I made of the Escort full flow and bypass filters. Gravitational settling would be just as effective on a full flow filter setting at rest, and the Brownian diffusion happens on a scale WAY smaller than what is presented in the typical oil filter media.
Again, I cannot find where these support your assertions.
